2004 Forester & trailer swaying [long]
C
chris
Several people have had good luck towing a trailer with previous model
Subaru Foresters. I do not know why mine is different.
I just bought a 2004 Forester tried to tow with it. Mine is a
nightmare. It is unstable above 40mph. It has a lot of side to side
sway above 40mph if there is any steering input. It is almost
harmonic in nature - it does not dampen out quickly. If feels like
you are driving on Jello. It feels like the problem is much more the
tires than the suspension. Though that is hard to prove.
Even when parked if you push on the hitch with your foot the Forester
will sway side to side [right and left] a lot. You can watch the rim
move right and left in and out of the tire. I think the sidewalls are
just really weak. The tread is probably relatively soft also.
The Forester's tires are
Yokohama Geolander G900 P215/60 R16 94H.
Even in normal driving the steering response and cornering are poor.
[Other Foresters may be equipped with 15" tires, and other models of
Geolander tires - rather than the G900].
My Mazda MX-6 [much lower car] has Pirelli P4000 P205/55 R15 87H - it
is stable, and if you push sideways it does not sway side to side
anywhere near the degree that the Forester does. Steering response
and cornering are good.
The Geolander G900 has a tall soft sidewall, it is 4.500" above the
rim rather than 3.625" for the P4000 [24%higher].
My best idea right now is to change to a shorter and stiffer sidewall
tire.
I am considering changing from P215/60 R16 94H
- an "H" rate tire with 60% width/height ratio, to
Bridgestone Turanza LS-V 225/50R16 92V - this is a V rate tire so the
sidewall is stiffer and at a 50 or 55 ratio it is shorter.
This is the V rated version of the tire that some other Forester
owners have [LS-H]. The tread should also be a harder sports car like
compound.
Some of these tires are rated and discussed on www.tirerack.com. It
seems that Steering response and cornering stability are good
expressions of my issue.
On tirerack there are a mass of good comments on the Turanza tire -
though I doubt anyone is towing. As far as I can tell everyone on
"tirerack" hates the geolander 900 like on mine.
Does anyone else have any Experience changing to a shorter V rated
tire for better stability?
My trailer does great and stable to 85+mph behind my Mazda MX-6, so I
do not think it is the trailer. The trailer weighs ~1800lbs [816kg].
The tongue weight is 153lbs [69kg]. The Forester's manual says to keep
the tongue weight between
8-11% of the trailer. 8%=144lbs [65kg] 11%=198lbs [90kg].
[the max allowed is 200lbs on the tongue] The manual transmission
version of the Forester is rated for 2400lbs [1088kg] towing capacity.
I have already tried raising the tire pressure on the rear tires to
41psi [2.8bar] as recommended by the manual. The trailer tires are
about 40psi.
Since my original write up I have learned the following:
The dealer told me that the 2004 model is the first to be equipped
with the Geolander G900 tires, previous years had a different model
tire. This is the only change to the suspension that he is aware of
between the 2003 and 2004 model.
The Maximum tire pressure on the tires is 44psi, so I upped the rear
pressure to 44psi and the fronts to 41. [for towing the manual says
29psi front, 41psi rear]. I also changed the hitch from a straight one
to a "drop hitch" it is now 1.5" lower than the straight one. The drop
hitch is about 4.0" shorter than the "lift hitch" [bent receiver
hitch] that I originally tried. The hitch ball is on a short receiver.
A test drive showed that the lower hitch/ball placement and the higher
tire pressures are an improvement. However still not acceptable. I
think the higher pressure stiffened the tires but not enough and the
tread is still too soft.
I have heard another Forester owner has had good luck with 75-100lbs
of tongue weight. An additional test drive was done after I moved
several items out of the front of the trailer to the back of the
Forester. This reduced the tongue weight to 118lbs [down 35lbs from
153]. The swaying seemed worse with the lower tongue weight. [This
follows the logic I have heard many times].
I would like to hear some other ideas, especially to know if others
have switched to better performing tires.
Chris
Trailer weight distribution is far more critical than one would think. I
have a friend who rolled his F150 while hauling a 16ft cargo which was
loaded waaaay wrong... going down a hill... started to sway.... bang... all
over in a heartbeat. totaled the truck and turned the trailer into a ball of
foil...
I try to have 10-15% of the total weight on the tongue as a general rule.
But your tires may need to be replaced...
David
1964 Karmann Ghia coupe
1998 Chev K1500
2000 Subaru Legacy GT
tire.
compound.
about 40psi.
Chris
<*Snip*>
Yes, your post was very long.. ;-)
My wife drives a 03 Forester. We have a 5X8 trailer that we use to
pull my motorcycle and other things. The trailer is rated for
2000lbs. One day I got some mulch that weighed about ~600lbs. I
noticed that the trailer was swaying on the highway on the way home.
I then checked the tire (tyre for our nonUS friends) pressure and
noticed it was a little low. So, I corrected it and also pumped up
the tire pressue on the car (check sticker on driver door frame). This
made a huge difference. Now everything is OK when driving.
Took the motorcycle (weighs about 430lbs)on vacation with me and drove
about 800 miles. No a problem with the trailer.
So, my advise is to check tire pressure and increase it to the
recommended towing pressure when you use the trailer. Also, only load
your trailer to 1/2 the load rating. These little utility trailers are
cheaply made and this load rating is (in my opinion) an absolute
limit. Should solve the problem.
I have a Forester MY01, and towed a 3300# trailer without any swaying
at all. Even when being passed by the big rigs there was no swaying.
The biggest thing here is 60% in front of the trailer axel and 40%
behind the trailer axel. And a even balance left and right. Your tires
may play part it this, but I don't believe to the same extend the
loading of the trailer. Loading your trailer to minimize your tongue
weight is probably what is causing the problem. If you have 60%/40%
balance and you are over your max. tongue weight then lighten the
trailer.
I once saw a guy towing a big power boat behind his Ford SUV
Expedition, it was swaying every where he went. And I suspect most of
his weight was on the tail end since that was where the motor
located!!!
Etienne
tire.
compound.
about 40psi.
Chris
Hi All!
trailer.
True story. You need a significant portion of the total trailer weight
on the trailer tongue (~10%). Hitch/ball height also plays a role; the
trailer should ideally be pretty level, and slight;y lower in the nose
is OK, but having the tongue end raised (hitch/ball too high) is
asking for trouble.
PebbleToTheKnee
