2003 Baja Trim Panel removal?
U
User705459
How do I get the trim panel(gray) off that is around the radio..I am
looking to replace the radio and I am afraid i am going to damage the panel
without correct instructions,,All I see is 2 screws above the ash tray once the
ash tray was removed.
[posted and mailed]
(e-mail address removed) (User705459) wrote in
panel without correct instructions,,All I see is 2 screws above the ash
tray once the ash tray was removed.
The instructions for installing the sub woofer contain the info. You can
download them here:
http://subaruparts.com/install/2002isub.pdf
am
ash tray once the ash tray was removed.
That is all that is holding it in. just remove the 2 screws, then pull
slowly at the bottom. you will have to unplug the lighter plug. the radio
bracket has 6 screws, 4 on the sides, 2 at the bottom.
when you put the radio bezzel back in, make sure to seat the top clips
first, if you don't you could break the IP (instument panel).
For pictures, check out http://www.butkus.org/outback_stereo/outback_stereo.html
Nicolas
Thank you all...I replaced the radio with one from a 2003 wrx....It was
very easy and a straight plug in..Once again thank you all
Stephengbear
