2001 forester(check engine light on)
Michel Chevalier
Hi
I replace all 4 spark plugs a week later check engine light came on it said
in the subaru booklet the gas cap to make sure its tight i did that or it
could be emission problem.Your help will be appreciate.
Thank
Mike
If gas cap first check the rubber cap seal. If it was not tightened or you
leave engine running while filling then the light will go off with about
10-15 start cycles. If it never goes of go to AutoZone to get a free readout
to identify the problem. ed
You might even try starting & stopping your engine 4 or 5 times. This is
what I have to do to get rid of the light, since the a diagnostic always
come up clean.
Phil
Watt
