Hi Ling!
Yea, it's the whole little panel; 4X windows, window lock, and door lock, at least on my '99 Forry. Bet your '00 car is pretty similar. Once it warmed up a bit this AM, I pulled it out and took a couple fotos for you. On this assembly, both ends were "push-in" clips. Lift the back (#1), lift the front, disconnect the plug, and it's yours (#2). Any time you are working with the interior plastic, you want things to be warm, or you increase the risk of breakage. Park in the sun, or a heated garage, or run the heater for awhile. FWIW, one of these switch assemblies will run $35 to $40 at a salvage yard. Have the bad one in your hand when you go, and plug in the replacement to check functionality before you leave. Check that all of the window switches on the doors work, too, as these all run thru the master switch. If you are handy, you might be able to disassemble the switch and repair it, but I've never tried. Nothing to lose, I guess, if it's _already_ broken. And you're quite welcome; that's why we're here. Oh, yea: If anyone else want's to see the fotos, drop me a line,an' I'll send 'em along.
Thanks Steve for the detailed answer. I really appreciate it. The master switch you referred to is the whole assembly (all 4 power window buttons, mirror buttons, power lock, etc), right?
