2000 Outback Keyless Entry Programming Button
L
leefriedman
I am looking for the programming button and might have found it - there
is a button that is part of the lower dash, just below the hood
release, but there is no ring around it like the literature indicates.
However, there are two brown wires that lead to it, which I believe
someone else said were the correct wires. Unfortunately, when I push
the button, nothing happens - no horn after 15 seconds. Any ideas on
how I should proceed? Is this even the correct button? I've looked
everywhere else and have found no other button.
Thanks.
Keyless entry programing on the 2001 involves using the ignition key and
doing a sequence of on/off with that.
Where are you finding information saying it is a button? In the manual?
zeushead01
