1995 Subaru Legacy L rear wheel ticking noise and front end clunk
Christopher (archive)
Usenet Archive
I own a 1995 Subaru Legacy L with two wheel drive and 115,000 miles. I have to different problems that I'm working on, but I wanted to hear some idea.
1) when driving I get a ticking sound (noise) coming from the rear end that increasing with the rate of travel. It isn't a grinding noise, but a tick, tick tick tick. I'm not sure if it's the brake drums or shoes or a wheel bearing or what exactly.
2) I replaced the front passenger side transaxle (CV joint) with a rebuilt one this summer and have gotten a single thunk or clunk whenever I turn and accelerate. While I was replacing the transaxle I also replaced the ball joint, but it appears to be well seated and the entire assembly is tight. (in other words if I try and shake everything from the strut assembly when it's on jack stands it isn't loose. I've also checked the CV joint and it's well installed. The locking pin is in place and the retaining nut at the end is properly torqued.
I would appreciate any help!
On pavement? Check the tread for a rock or stone or other object. One might not expect the object to hit the ground going very fast, but they do... and can make quite a pronounced tick on each revolution. (If it's a nail or something, make sure your spare has air in it before messing with the object in case it's a puncture.)
Dunno on that.
I'm not sure that this applies here or not,
but I was taught that you can't always judge
front end tightness when the front end is
jacked up. Jacking the car up allows the
suspension springs to expand, taking the slop
out of things.
out of things.
I'll check for something in the tires. As far as the front suspension. I've checked for slop while it's up in the air and the whole assembly is pretty tight. I read the trouble shooting section in the Haynes Manual and it leads me to believe it might be a bad inner cv joint (even though the part is brand new it might be defective.)
I've checked for things stuck in the tire (nails, rocks, bolts, etc.) but found nothing. What else could make the clicking noise in back? It's two wheel drive so there isn't any driveline compenents that would cause it. All I can come up with is either the brakes or the wheel bearing?
Any other ideas?
Christopher
Found the clicking noise in back ended up being the brake drums. Funny enough, the pads are actually in excellent shape but the outside flange on the brake drum had rusted apart and actually partly broken off. I've never seen anything similar ever happen on a car. I'm glad it's fixed.
I believe the loud clunk in from is probably a poor aftermarket cv joint. I'll have to take it back to the auto parts store for a replacement. It came with a lifetime guarantee.
Subject: Re: 1995 Subaru Legacy L rear wheel ticking noise and front end clunk
Any other ideas?
Christopher
Wheel bearing or even a loose hub cap sometimes does this as the wheel flexes.
msb
