1995 awd legacy man. trans rebuild
mp
hello,
I have a 95 awd manual legacy w/ 150k.
I have been told by several trans shops that the trans needs rebuilding -
bearings appear to be shot.
1) what would cause the bearings to fail - trans oil has been changed and
was not low
2) I've been quoted between 900 - 3500 for the work. has anyone else had
this done? how much?
3) I'm in RTP, NC - any suggestions?
thanks
mp
mp said:
hello,
was not low
Let me guess... 150,000 miles?
Not in years, but the 3500 sounds high, but then I would go with the
shop I knew and trusted
Let's see, several shops tell you to rebuild it, I would say ignore it
and scrape the car when it dies
hello,
rebuilding - bearings appear to be shot.
What are your symptoms? My 95 is only at 100k miles and runs great, but
there is a strange "rubbing" noise that comes from the transmission - and
your post makes me worry that it is impending bearing failure.
We've had the car since it was new. It was passed down to me from my wife
last summer (finally get AC that the 76 VW didn't have ;-)
I haven't noticed a distinctive change in the "sound" of the trans - with
road noise, engine noise, kids screaming ;-)
When the car is idling in neutral w/ teh clutch out, there is a rubbing(?)
rumbling sound. When I press the clutch in, the sound pretty much stops. I
was told that this is indicative of a bearing that is about to come apart &
ruin my whole trans.
Driving in 1st is loudest, 2nd loud, 3rd ok, 4 quieter - but I still can't
notice the gradual change in trans noise.
The other thing it is doing is making a clacking sound when turning - but
not all the time. It is NOT the CVs. I had them replaced last year & 3
shops have inspected them. I think it is coming from the trans, but they do
not know what it is. I'm thinking w/ the AWD, turning can put additional
strain on the front drive axle bearing???
Could it be the rack & pinion? I have not ever had a steering problem.
But, if it's the rack & the trans, I may be back in the 76 VW for another
long summer.
Stephengbear
