Subaru Car Forums
Reply
Thread Tools Display Modes
2001 Subaru Outback: clicking noise when stepping on the brake?
spartacu33
Guest
Posts: n/a
      12-14-2008
I have a 2001 Subaru Outback and when it's in Park with the key on and
step on the brake, it makes a fairly loud clicking noise between th
radio and the glove box. Only happens when the key is on.
When in Reverse or Drive... and I step on the brake it doesn't mak
this noise.
Any ideas?
Thanks in advanc
spartacu3
Message Origin: TRAVEL.co
Carl 1 Lucky Texan
Guest
Posts: n/a
      12-15-2008
spartacu33 wrote:
> I have a 2001 Subaru Outback and when it's in Park with the key on and I
> step on the brake, it makes a fairly loud clicking noise between the
> When in Reverse or Drive... and I step on the brake it doesn't make
> this noise.
> Any ideas?
> Thanks in advance
Maybe the Neutral Safety?
to reply, change ( .not) to ( .net)
AS
Guest
Posts: n/a
      12-16-2008
The noise is caused by the shifter lock solenoid, the one that prevents
shifting into gear unless you are stepping on the brake pedal.
Good luck
> this noise.
> Any ideas?
> Thanks in advance
.._..
Guest
Posts: n/a
      12-16-2008
It's normal.
"AS" <(E-Mail Removed)> wrote in message
news:(E-Mail Removed) m...
> Good luck
>> this noise.
>> Any ideas?
>> Thanks in advance
JVC Dude
Guest
Posts: n/a
      12-19-2008
My 03 Outback doesn't have the solenoid click or the need to put the brake
on before shifting..... again normal I suppose...probably a different
gearbox?
Cliff
".._.." <(E-Mail Removed)> wrote in message
news:PAP1l.346$(E-Mail Removed).. .
> It's normal.
> > Good luck
I
> >> this noise.
> >> Any ideas?
> >> Thanks in advance
AS
Guest
Posts: n/a
      12-20-2008
Manual tranny in your car?
> gearbox?
> Cliff
>>It's normal.
>>news:jOSdncNhzolviNrUnZ2dnUVZ_rHinZ2d@earthlink. com...
>>>Good luck
> I
>>>>this noise.
>>>>Any ideas?
>>>>Thanks in advance
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
2001 H6 Subaru Outback Wagon auto transmission noise Koen Subaru Outback 7 05-31-2006 07:22 PM
Ball joints replaced - new clicking noise mtoll24 General Motoring 4 03-30-2006 01:32 AM
Brake pads - 2001 Outback wagon EL Subaru Outback 2 05-13-2005 01:10 PM
2001 Outback Ltd engine noise Crabby Gator Subaru Outback 3 03-15-2005 01:32 AM
2001 Outback brake problem IDG Subaru Outback 1 02-17-2005 01:57 AM
