Subaru Car Forums
Reply
Thread Tools Display Modes
98 subaru outback transmission filter change?
yakinikuta@yahoo.com
Guest
Posts: n/a
      12-12-2006
I have the 98 Subaru outback recently and I would like to change the
transmission filter, but the filter is inside the pan. Is that possible
for me to unseal the pan and open it to change the filter?
Oscar_Lives
Guest
Posts: n/a
      12-13-2006
<(E-Mail Removed)> wrote in message
news:(E-Mail Removed) oups.com...
Only you can answer that. We don't know your skills and intelligence.
JohnO
Guest
Posts: n/a
      12-13-2006
My '99 has a filter on the outside, looks like a small oil filter. It's
on the driver's side of the tranny, just about directly under the
firewall, on top. I replaced it with the car jacked up a couple inches,
no tools needed.
-John O
Guest
Posts: n/a
      12-13-2006
> no tools needed.
> -John O
Thanks for telling that, but my filter is inside the pan...i can't open
it w/ the sealed pan
JohnO
Guest
Posts: n/a
      12-13-2006
> > no tools needed.
> > -John O
I didn't think mine had an external filter, but it turns out I was
mistaken. Maybe mine was the first model year for that.
-John O
Trlather@comcast.net
Guest
Posts: n/a
      12-14-2006
Don't bother, not necessary, just change the ATF on a regular basis
fish6525@yahoo.com
Guest
Posts: n/a
      12-14-2006
Everything that I have read is to not drop the pan to replace the
internal filter. That filter is nothing more then a screen. The problem
is that it can be very difficult to reseal the pan without it leaking.
I have been told that starting in '98, Subaru added a spin on filter. I
haven't seen it, but it looks like an oil filter. That should be easy
to replace. Filter is prolly down very low on a frame rail under the
car. Follow the fluid lines back from the radiator cooler to find the
spin on filter.
Suggest changing the ATF by removing the drain plug on the bottom of
the trany. That will drain about 5 quarts out of about 10 quart system
capacity. You can also take your car to a quick change oil shop, many
of those have a machine that will remove all the old fluid from the
trany. Cost at my local Jiffy Lube was $175 for the job.
BobN
Guest
Posts: n/a
      12-14-2006
news:(E-Mail Removed) ups.com...
Sheesh. My local Goodyear/Gemini shop quoted $130.
Jim Stewart
Guest
Posts: n/a
      12-14-2006
> spin on filter.
The power flush is a *good thing*. Just
draining the fluid leaves a large quantity
of old that never gets replaced. If you're
going to go to the trouble of a change, the
best way is the power flush.
Edward Hayes
Guest
Posts: n/a
      12-14-2006
My local Pennzoil quick lube place said they will not do a flush on a
vehicle with over 100,000 miles and I have 114,000. I will keep doing
a plug & refill every 25-30,000 miles.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
98 subaru outback transmission filter change? yakinikuta@yahoo.com Subaru Outback 0 12-12-2006 10:27 PM
98 subaru outback transmission filter change? yakinikuta@yahoo.com Subaru Outback 0 12-12-2006 10:23 PM
Transmission oil change on 2005 Outback roofgunner Subaru Outback 3 05-27-2006 09:59 AM
how to change a fuel filter in an impreza wrx matt Subaru Impreza 2 09-03-2005 10:33 PM
2001 Outback Transmission Fluid Change Adam Subaru Outback 12 07-17-2004 05:45 PM
