Subaru Car Forums
Reply
Thread Tools Display Modes
96 Outback won't start
avaholic21
Guest
Posts: n/a
      10-27-2006
Greetings- I'm a frequent lurker, first time poster, so please bear
with me. I have a '96 Legacy Outback 2.2L that won't start. I've read
posts regarding the crank/cam sensors and suspected that at first. I
have spark at the plugs and no codes from my Actron OBDII reader
leading me to suspect fuel pump/relay/etc. My question is... If the car
won't start, will I get a DTC for any faults. I'm assuming since I do
have a spark, my problem is not ignition/electrical. Any insight would
be great...!
Thanks in advance
AS
Guest
Posts: n/a
      10-28-2006
You may get a code but not necessarily.
Have you tried pinching the fuel line and then turning the ignition
switch on? Do you feel the hose getting stiffer? This will help
determine if you have fuel pressure.
Do you smell gas? The engine could be flooded, flooring the gas pedal
while cranking the engine cuts the fuel supply and helps start the engine.
Good luck
> be great...!
> Thanks in advance
avaholic21
Guest
Posts: n/a
      10-30-2006
AS- Thanks for the reply. It turns out the fuel pump went out on me.
Your suggestion for testing fuel pressure (among others gleaned from
this NSG) helped me diagnose the culprit.
Thanks Again...!
> Good luck
> > be great...!
> > Thanks in advance
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Subaru Outback 2001 - won't start batvanio@gmail.com Subaru Outback 7 05-20-2008 09:20 AM
Outback won't start. Won't do *anything* Jason Subaru Outback 9 04-23-2007 02:14 PM
'95 Outback that won't start tonyrama Subaru Outback 7 09-02-2004 05:02 AM
Remote Start on '02 Outback Kurt C. Hack Subaru Outback 0 03-02-2004 01:42 AM
96 Legacy Outback that doesn't like to start Karl Saal Subaru Legacy 3 11-11-2003 10:07 PM
