Subaru Car Forums
Reply
Thread Tools Display Modes
2002 Forester O2 Sensor
phatirejunky
Guest
Posts: n/a
      06-12-2005
I had an intermittent engine miss, and also a general lack of power.
The milage on this subie is 70,000. The CEL never came on. I tried
the obvious, fuel filter, plugs, wires. I finally let local shop have a
go, they couldn't find problem. I then decided to try closest dealer.
They diagnosed as worn clutch, $1,100. I declined their offer and paid
$44 for diagnosis. I had searched this NG and found a few other posts
that had similar problem. The front O2 sensor was the culprit. I
changed the sensor and car has been running good ever since. Initially
when the problem started, I was sure I had water in the gas. I even
used dry gas and the symptoms didn't seem as bad. The problem
persisted for months. It was most noticible when climbing long hills,
miss fire, run o.k., miss fire. I wish the CEL had come on, it would
have been easy to diagnose. Hope this helps others with similar issues
of poor performance.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
O2 sensor on 2002 Legacy Cliff Top Subaru Legacy 6 12-08-2006 12:34 PM
Forester TPS sensor frustratedforester Subaru Forester 0 08-02-2006 11:41 AM
O2 sensor on Forester Hobbs Family Subaru Forester 0 04-25-2006 07:50 PM
Knock Sensor 2002 Outback... Safe to drive? scowsert@gmail.com Subaru Outback 4 03-10-2005 04:47 PM
2001 Forester O2 sensor help kleinux Subaru Forester 13 11-06-2003 05:06 PM
