Subaru Car Forums
Reply
Thread Tools Display Modes
Forester XT torque curve
TransFixed
Guest
Posts: n/a
      08-10-2003
In the middle of April, when there were many questions about the
performance and power of the Forester XT, I made an educated guess about
its torque curve. Here is what I wrote then, with Nm quantities
included now for convenience:
RPM lb-ft Nm
1600 ~160 217 [from base 2.5l engine +AVCS +turbo]
2000 ~190 258 [from base 2.5l engine +AVCS +turbo]
3600 ~235 319 [official spec]
4600 ~220 298 [interpolated]
5600 ~200 271 [official spec, converted from max hp (197, exactly)]
6000 ~180 244 [interpolated from 2.5l + turbo specs, and max hp
cond.]
6400 ~160 217 [interpolated from 2.5l + turbo specs, and max hp
cond.]
Now, Subaru of Australia has published the actual torque curve of the XT
(http://subaru.com.au/downloads/929305.pdf ). You can see that my
estimate was within a felt-tip pen stroke (a very few percent) of this
curve. Interestingly, I left out the area between 2000rpm and 3600rpm
because I could not figure that one out. It turns out that there is a
slight saddle in the torque curve there – but nothing to be concerned about.
Other than patting myself on the shoulder here, I want to point out that
it is quite possible to get a good idea of an engine’s performance from
a few data points and specs that are available.
The above .pdf file is also describes other engine features quite nicely.
- D.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Torque Tcassette General Motoring 3 09-21-2006 01:34 AM
Wheel nut torque?? Jim General Motoring 7 04-09-2006 02:57 PM
Head torque on EA81? Al Blake General Motoring 8 10-19-2005 09:26 PM
torque binding? hundog@gmail.com General Motoring 3 09-21-2005 02:54 AM
Torque distribution Sai General Motoring 3 04-09-2004 08:50 PM
